SNMP Problem in 1.8.4
  • fratotec
    • May 2010
    • 12
    Hello ...
    it seems there is some "inconsistence" in SNMP polling in version 1.8.4.
    I use SNMP for polling router and switch uptime, and created a trigger like {Uptime.change(0)}>1 .. to alert me when a device is rebooting.
    after upgrade from 1.8.4rc2 to 1.8.4 I received tons of alerts. After looking at the last 500 values, I saw:
    2011-03-18 11:11:39 1300457499 13707
    2011-03-18 11:10:38 1300457438 13646
    2011-03-18 11:09:40 1300457380 13588
    2011-03-18 11:08:41 1300457321 13529
    2011-03-18 11:08:39 1300457319 13527
    2011-03-18 11:07:42 1300457262 13470
    2011-03-18 11:07:41 1300457261 13469
    2011-03-18 11:06:41 1300457201 13409
    it seems that even configured for a 60 second interval, he checks 2x a minuto.. sometimes the same second, sometimes 2 seconds later..
    when the last value is the same as the previous, the trigger fires.
    shutting down zabbix_server 1.8.4 and starting-up the saved 1.8.4RC2 version ... and all works like expected.
    2011-03-18 11:36:41 1300459001 15209
    2011-03-18 11:35:40 1300458940 15148
    2011-03-18 11:34:39 1300458879 15087
    2011-03-18 11:33:38 1300458818 15026
    2011-03-18 11:32:42 1300458762 14970
    2011-03-18 11:31:39 1300458699 14907
    2011-03-18 11:30:40 1300458640 14848
    2011-03-18 11:29:38 1300458578 14786
    one check / minute.
    Any ideas ?
    Franz
  • captaincarisma
    • Mar 2011
    • 16
    I have this problem, i active all service but after few second the service is not supported why???
    • captaincarisma
      • Mar 2011
      • 16
      help me please
      • C. Vermeren
        • Apr 2011
        I had the same problem.
        I changed on the host configuration from "connect to : DNS name" to
        "connect to : ip address" and that solved my problem.
        Kind regards,
        • untergeek
          • Jun 2009
          • 512
          I went to check if mine was connecting via DNS and it was already pointing to IP. This did not correct my problem.
          • captaincarisma
            • Mar 2011
            • 16
            the problem is not solved. Can anyone help me?
            • captaincarisma
              • Mar 2011
              • 16
              help me please
