I need compose a very large trigger. It is a result of a karnaugh map with 5 variables.
It should not trigger only when user1 or user2 or user3 login on a server between 8:00h and 18:00h. These users in other time or other users in any time should trigger an action.
These complex condition gives me the trigger showed below
({Template_Linux_Vpn:login.access.regexp(user1)}=0 &
{Template_Linux_Vpn:login.access.regexp(user2)}=0&
{Template_Linux_Vpn:login.access.regexp(user3)}=0)
{Template_Linux_Vpn:login.access.time(0)}<080000)
{Template_Linux_Vpn:login.access.time(0)}>180000)
{Template_Linux_Vpn:login.access.regexp(user3)}=0&
{Template_Linux_Vpn:login.access.time(0)}>180000)|
({Template_Linux_Vpn:login.access.regexp(user2)}=0 &
Part of it, when I inserted it on Zabbix, is cut. I think this is becouse it is too large.
So, when I exclude one of the users from the condition, the trigger becomes smaller and enters full in Zabbix. And works fine.
So finaly, is there a way to increase the trigger size?
