SSL Certificate Problem
  • dpbaker57
    • Aug 2010
    • 33
    I'm monitoring a site and having an issue with a site's SSL certificate.
    It is an issue that requires the -k or --insecure option with curl. Is there anyway to tell Zabbix (1.8.4) not to validate it?
    $ curl https://site-obscured.com/roi/servle...yAction=Status us
    curl: (60) SSL certificate problem, verify that the CA cert is OK. Details:
    error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
    More details here: http://curl.haxx.se/docs/sslcerts.html
    curl performs SSL certificate verification by default, using a "bundle"
    of Certificate Authority (CA) public keys (CA certs). If the default
    bundle file isn't adequate, you can specify an alternate file
    using the --cacert option.
    If this HTTPS server uses a certificate signed by a CA represented in
    the bundle, the certificate verification probably failed due to a
    problem with the certificate (it might be expired, or the name might
    not match the domain name in the URL).
    If you'd like to turn off curl's verification of the certificate, use
    the -k (or --insecure) option.
    $ curl -k https://site-obscured.com/roi/servle...yAction=Status
    <HTML><HEAD><TITLE>Status</TITLE></HEAD><BODY><H1>Status: GREEN</H1></BODY></HTML>
  • Rudd
    • Mar 2011
    • 69
    You monitor a site using a Web Scenario?
    I've got a few Web Scenarios hitting SSL sites with self signed certificates. I was not aware Zabbix tried to validate the certificate path. The Zabbix tests work out of the box for me. Running curl from the command line obviously results in the same error you described as I never loaded the CA.
    Can you provide some more information on what is actually configured in Zabbix?
    While waiting for a helpful answer I would probably try to add the CA to the ca-bundle.crt on the server.
    • dpbaker57
      • Aug 2010
      • 33
      Zabbix configuration
      It is a website trigger with the expression:
      {Website_Monitor:web.test.fail[SITE_Status_Page].sum(#7)}>3
      And URL:
      The actual monitor has only one step:
      expecting the page to return 200 or 210 and contain the work GREEN
      This is one of many web monitors we have many if not most running SSL. The site is running WebSphere and IIS.
      I'm thinking I might add the certificate to the "bundle" on the server. I'm not sure how curl/curllib would react to that.
      • dpbaker57
        • Aug 2010
        • 33
        Here is the full output of "openssl s_client -connect express.rwsol.com:443"
        depth=0 /C=US/ST=Wisconsin/L=Waukesha/O=Connecture, Inc/OU=IT/OU=Terms of use at www.verisign.com/rpa (c)05/CN=express.rwsol.com verify error:num=20:unable to get local issuer certificate verify return:1 depth=0 /C=US/ST=Wisconsin/L=Waukesha/O=Connecture, Inc/OU=IT/OU=Terms of use at www.verisign.com/rpa (c)05/CN=express.rwsol.com verify error:num=27:certificate not trusted verify return:1 depth=0 /C=US/ST=Wisconsin/L=Waukesha/O=Connecture, Inc/OU=IT/OU=Terms of use at www.verisign.com/rpa (c)05/CN=express.rwsol.com verify error:num=21:unable to verify the first certificate verify return:1
        CONNECTED(00000003)
        Certificate chain
        0 s:/C=US/ST=Wisconsin/L=Waukesha/O=Connecture, Inc/OU=IT/OU=Terms of use at www.verisign.com/rpa (c)05/CN=express.rwsol.com
        i:/C=US/O=VeriSign, Inc./OU=VeriSign Trust Network/OU=Terms of use at https://www.verisign.com/rpa (c)10/CN=VeriSign Class 3 Secure Server CA - G3
        Server certificate
        -----BEGIN CERTIFICATE-----
        MIIFPDCCBCSgAwIBAgIQZkdxU4VHBi22/NLKI+D0ADANBgkqhkiG9w0BAQUFADCB
        tTELMAkGA1UEBhMCVVMxFzAVBgNVBAoTDlZlcmlTaWduLCBJbm MuMR8wHQYDVQQL
        ExZWZXJpU2lnbiBUcnVzdCBOZXR3b3JrMTswOQYDVQQLEzJUZX JtcyBvZiB1c2Ug
        YXQgaHR0cHM6Ly93d3cudmVyaXNpZ24uY29tL3JwYSAoYykxMD EvMC0GA1UEAxMm
        VmVyaVNpZ24gQ2xhc3MgMyBTZWN1cmUgU2VydmVyIENBIC0gRz MwHhcNMTAxMTAx
        MDAwMDAwWhcNMTExMjMxMjM1OTU5WjCBrDELMAkGA1UEBhMCVV MxEjAQBgNVBAgT
        CVdpc2NvbnNpbjERMA8GA1UEBxQIV2F1a2VzaGExGDAWBgNVBA oUD0Nvbm5lY3R1
        cmUsIEluYzELMAkGA1UECxQCSVQxMzAxBgNVBAsUKlRlcm1zIG 9mIHVzZSBhdCB3
        d3cudmVyaXNpZ24uY29tL3JwYSAoYykwNTEaMBgGA1UEAxQRZX hwcmVzcy5yd3Nv
        bC5jb20wgZ8wDQYJKoZIhvcNAQEBBQADgY0AMIGJAoGBALxPy9 Vjf+tgOVKKNV1e
        dD8CBbG0zJaECwwYU2F/sCaVide18Cia1oGokMD9c1HI8zxkr02JnuB/waV5eSca
        odJ3RMJj4Wyy1gj8UizV5lGTElJiZscbFxwGLaz5XzSFHb5o54 xqjvShGCXnxM0J
        Q+sUXwBCDcTYhtgRQAPknS2ZAgMBAAGjggHRMIIBzTAJBgNVHR MEAjAAMAsGA1Ud
        DwQEAwIFoDBFBgNVHR8EPjA8MDqgOKA2hjRodHRwOi8vU1ZSU2 VjdXJlLUczLWNy
        bC52ZXJpc2lnbi5jb20vU1ZSU2VjdXJlRzMuY3JsMEQGA1UdIA Q9MDswOQYLYIZI
        AYb4RQEHFwMwKjAoBggrBgEFBQcCARYcaHR0cHM6Ly93d3cudm VyaXNpZ24uY29t
        L3JwYTAdBgNVHSUEFjAUBggrBgEFBQcDAQYIKwYBBQUHAwIwHw YDVR0jBBgwFoAU
        DURcFlNEwYJ+HSCrJfQBY9i+eaUwdgYIKwYBBQUHAQEEajBoMC QGCCsGAQUFBzAB
        hhhodHRwOi8vb2NzcC52ZXJpc2lnbi5jb20wQAYIKwYBBQUHMA KGNGh0dHA6Ly9T
        VlJTZWN1cmUtRzMtYWlhLnZlcmlzaWduLmNvbS9TVlJTZWN1cm VHMy5jZXIwbgYI
        KwYBBQUHAQwEYjBgoV6gXDBaMFgwVhYJaW1hZ2UvZ2lmMCEwHz AHBgUrDgMCGgQU
        S2u5KJYGDLvQUjibKaxLB4shBRgwJhYkaHR0cDovL2xvZ28udm VyaXNpZ24uY29t
        L3ZzbG9nbzEuZ2lmMA0GCSqGSIb3DQEBBQUAA4IBAQBkFabUxI NtVHRryj41mdU7
        hHLSryW2wxo+HTeO4akaWGlVrYmCtxqolXhxclOYL+0W+TS8ak/+FjcZAEZl05nZ
        /srWOEW2I0RrMghh0N8dDlpdoJSFWY2S2JLvKcrxNgqpH5t4ExU xxZTqYzbDoU6n
        QXW7h3sGA9V+7f2tA8E3MOAQt3CnYUdQO0CUo6cKc2XG3n/srgmJxkRBBQEX/pXE
        az++GNVQGla5uLaWoiKdhgAJGL2E1b4cF4fPDskwe3z6jCLH+q LtSfqQgpDLT6i0
        oiVETQd0AMkgC7H2mBkUL/2Fg59fJE8Fg0DMkSY6yM8OSJM5tTzbhZpaA6JeD6jO
        -----END CERTIFICATE-----
        subject=/C=US/ST=Wisconsin/L=Waukesha/O=Connecture, Inc/OU=IT/OU=Terms of use at www.verisign.com/rpa (c)05/CN=express.rwsol.com issuer=/C=US/O=VeriSign, Inc./OU=VeriSign Trust Network/OU=Terms of use at https://www.verisign.com/rpa (c)10/CN=VeriSign Class 3 Secure Server CA - G3
        No client certificate CA names sent
        SSL handshake has read 1498 bytes and written 311 bytes
        New, TLSv1/SSLv3, Cipher is DES-CBC3-SHA Server public key is 1024 bit Secure Renegotiation IS NOT supported
        Compression: NONE
        Expansion: NONE
        SSL-Session:
        Protocol : TLSv1
        Cipher : DES-CBC3-SHA
        Session-ID: 6B66A407A2B0146FEB5276FFDC6B78C406E18E243DCB7C36AF 17F405F7C07E7C
        Session-ID-ctx:
        Master-Key: B4E79C35ED62B921E3EDEF1309EEB536BD98A1087B0E64940B 74A43434F238BB2F112AE6A23A95492B22BFB1F2701759
        Key-Arg : None
        Start Time: 1302015075
        Timeout : 300 (sec)
        Verify return code: 21 (unable to verify the first certificate)
        DONE
        • Rudd
          • Mar 2011
          • 69
          "VeriSign Class 3 Secure Server CA - G3" is not a root certificate and your server does not send the certificate chain. Hence the verification fails. In your example the sslclient is connected though, albeit with a warning.
          If you believe that the certificate chain is the problem you could have your server send the intermediate certificate (http://SVRSecure-G3-aia.verisign.com/SVRSecureG3.cer) as well.
          Having said that, I don't think Zabbix tries to validate the certificate chain. I am successfully monitoring SSL web servers with self signed certificates. They warn as well when I connect using openssl or curl. Your scenario is somewhat different of course.
          • dpbaker57
            • Aug 2010
            • 33
            I'm curious why this one site of the dozens we monitor is having issues. A number of the using wildcard certs which usually causes problems. I suspect this cert was formed or installed in some idiosyncratic way. If I find out what is wrong I will post to this thread.
            • dpbaker57
              • Aug 2010
              • 33
              Fixed Cert. Curl Happy. Zabbix not!
              As you can see below curl is now fine with the certificate as updated. My web site monitor is still getting "Fail - Error: SSL connect error" Not the most useful error message and the server log file is not any better:
              12973:20110408:133530.979 Web scenario step [WPIFP_Status_PageisplaySystemStatus] error: error doing curl_easy_perform: SSL connect error
              root@ctsms2:~# curl https://express.rwsol.com/roi/servle...yAction=Status
              root@ctsms2:~#
              root@ctsms2:~# openssl s_client -connect express.rwsol.com:443 < /dev/null 2>&1
              CONNECTED(00000003)
              depth=2 /C=US/O=VeriSign, Inc./OU=VeriSign Trust Network/OU=(c) 2006 VeriSign, Inc. - For authorized use only/CN=VeriSign Class 3 Public Primary Certification Authority - G5
              verify return:0
              Certificate chain
              1 s:/C=US/O=VeriSign, Inc./OU=VeriSign Trust Network/OU=Terms of use at https://www.verisign.com/rpa (c)10/CN=VeriSign Class 3 Secure Server CA - G3
              i:/C=US/O=VeriSign, Inc./OU=VeriSign Trust Network/OU=(c) 2006 VeriSign, Inc. - For authorized use only/CN=VeriSign Class 3 Public Primary Certification Authority - G5
              2 s:/C=US/O=VeriSign, Inc./OU=VeriSign Trust Network/OU=(c) 2006 VeriSign, Inc. - For authorized use only/CN=VeriSign Class 3 Public Primary Certification Authority - G5
              i:/C=US/O=VeriSign, Inc./OU=Class 3 Public Primary Certification Authority
              Server certificate
              SSL handshake has read 4260 bytes and written 311 bytes
              Compression: NONE
              Expansion: NONE
              SSL-Session:
              Protocol : TLSv1
              Session-ID: 1E7D83B4D48052683952D1C62A4BCFA29E9E06B88787185035 4E438307ABB481
              Session-ID-ctx:
              Master-Key: 0B404878DB94DB0D78E7B99D0BF5868FCA6C68E53F3D3FC01E 0C2CBC3FD8CFF59AC306148BAF61BE6B0E4C5F0913B92C
              Key-Arg : None
              Start Time: 1302286229
              Timeout : 300 (sec)
              Verify return code: 20 (unable to get local issuer certificate)
              DONE
              root@ctsms2:~#
              • dpbaker57
                • Aug 2010
                • 33
                Moving this to problem forum
                I am moving this to the problem forum since I now believe this is a Zabbix problem and not my configuration.
