flexible interval put back
  • Biobabar
    • Jan 2011
    • 15
    Hello !
    I'm using 1.8.3 zabbix agent for windows
    I want verify if my directory is empty.
    My key is : system.run[dir c:\EDI_PLAN\CDE\ | find "fichier(s)"]
    Type of information : Text
    Update interval (in sec) : 0
    Flexible intervals (sec) : 7200 sec at 1-5,05:30-19:35
    I want a reel flexible intervals between 07:30-21:35 but with my UTC +2, it does not work properly.
    The answer is good but, the real problem, it's I have my first information at 8h30 and not 7h30...
    Where is the error ??
  • Biobabar
    • Jan 2011
    • 15
    I add I have already another key
    key : system.run[dir c:\EDI_PLAN\BL\ | find "fichier(s)"]
    Flexible intervals (sec) : 7200 sec at 1-5,06:30-20:35
    Here, it's a good return at a good time !
    first return--> 31 Mar 2011 08:31:31 0 fichier(s)
    Why for the Flexible intervals "7200 sec at 1-5,05:30-19:35" the first return is at 08:30 too?
    Thank you for your help
    • Biobabar
      • Jan 2011
      • 15
      For one, I have :
      with result :
      from 8h30 to 22h30 with 2h intervals
      (GOOD)
      And another :
      with result :
      from 8h30 to 20h30 with 2h intervals
      I don't understand...
      • Biobabar
        • Jan 2011
        • 15
        some test with different "flexible intervals":
        it's start at :
        logically --> real
        5:30 --> 8:30
        5:00 --> 8:30
        4:30 --> 7:30
        4:00 --> 7:30
        3:30 --> 6:30
        3:00 --> 6:30
        2:30 --> 5:30
        2:00 --> 5:30
        I need to start at 7:30... So I will start at 4:30
        But it's very strange
