problem with icmpping
  • mhabdank
    • Feb 2011
    I'v created item which is using simplecheck icmpping (attached).
    in zabbix_server.conf
    FpingLocation=/usr/sbin/fping
    on server when i run:
    [root@zabbix ~]# su zabbix --shell=/bin/bash
    bash-4.1$ /usr/sbin/fping 10.5.172.5
    10.5.172.5 is alive
    but item always see host as down (has value 0).
    how should i use this item correctly?
    best regards
    Mikolaj Habdank
    18623:20110401:121250.630 In substitute_simple_macros() data:'icmpping'
    18623:20110401:121250.630 In add_icmpping_item() addr:'10.5.172.5' count:3 interval:0 size:0 timeout:0
    18623:20110401:121250.630 End of add_icmpping_item()
    18623:20110401:121250.630 In DCflush_nextchecks()
    18623:20110401:121250.630 End of get_pinger_hosts():1
    18623:20110401:121250.630 In process_pinger_hosts()
    18623:20110401:121250.630 In add_pinger_host() addr:'10.5.172.5'
    18623:20110401:121250.630 End of add_pinger_host()
    18623:20110401:121250.630 In do_ping() hosts_count:1
    18623:20110401:121250.630 In process_ping() hosts_count:1
    18623:20110401:121250.631 /tmp/zabbix_server_18623.pinger
    18623:20110401:121250.631 10.5.172.5
    18623:20110401:121250.631 /usr/sbin/fping -q -C3 2>&1 </tmp/zabbix_server_18623.pinger;/usr/sbin/fping6 -q -C3 2>&1 </tmp/zabbix_server_18623.pinger;
    18623:20110401:121251.086 Update IP [fping6: Address family for hostname not supported]
    18623:20110401:121251.086 End of process_ping()
    18623:20110401:121251.087 End of do_ping():SUCCEED
  • Rudd
    • Mar 2011
    • 69
    Looks like the Key does not contain the actual address to ping.
    You can use real addresses or macro values, handy in templates:
    icmpping[8.8.8.8,4,,,,avg]
    icmpping[{IPADDRESS},4,,,,avg]
