log file monitor
  • MMK
    • Mar 2010
    log file monitor
    How i can monitor log file (windows). File format is log_yearmonthday.log (log_20110406.log).
    I try alias in zabbix_agentd.conf
    Alias=test.log:"C:\log_%date:~9,4%%date:~6,2%%date :~3,2%.log"
    and item
    zabbix_agent active
    log[test.log,,,100]
    result is not supported
    Can some one help me.
    Br. MMK
  • Rudd
    • Mar 2011
    • 69
    You don't need an alias in zabbix_agentd.conf.
    Try Zabbix agent (active) with: "logrt[G:\Path\to\logs\log_*.log,,,100]"
    • MMK
      • Mar 2010
      But every day create a new log file. How to monitor the latest?
      • Rudd
        • Mar 2011
        • 69
        The Zabbix developers thought about that That is why they allow wild cards and pattern matching. The before mentioned item should pick up on newly created logfiles.
        Have a look here for more information: http://www.zabbix.com/documentation/...g/how_it_works
