Update interval and Flexible intervals
  • Ajmal
    • Apr 2011
    Hi All,
    I need help for configuring Flexible intervals.
    I just tried but not working as expected.
    I need to do log file monitoring in a specific day at a specific time only.
    Regards,
    Ajmal
  • qix
    • Oct 2006
    • 423
    you could use a cronjob with the zabbix_sender.
    With kind regards,
    Raymond
    • Ajmal
      • Apr 2011
      I have not used zabbix_sender.
      I am using ZABBIX_Agent,and I am monitoring multiple thing.
      So for one Item Ineed to monitor once in a day.
      So is it possible to do by using "Flexible intervals" in Item configuration?
      Thanks in Advance.
      Ajmal
      • qix
        • Oct 2006
        • 423
        I would not think it will work, just use zabbix_sender for that
        With kind regards,
        Raymond
