SNMP Not Supported
  • captaincarisma
    • Mar 2011
    • 16
    SNMP Not Supported
    I want to monitor a switch, create host with the ip address of my switch, I associate a template but after a few minutes this happens in the picture, can anyone help?
  • qix
    • Oct 2006
    • 423
    wrong snmp community string perhaps?
    With kind regards,
    Raymond
    • captaincarisma
      • Mar 2011
      • 16
      The community string is correct
      • qix
        • Oct 2006
        • 423
        Are the OIDs that are queried correct?
        You can do a snmpwalk or snmpget to verify.
        With kind regards,
        Raymond
        • captaincarisma
          • Mar 2011
          • 16
          The response of snmpwalk and snmpget is
          Timeout: No Response from "ip switch"
          I have used this command
          snmpwalk -v 2c -c "community name" -On "ip switch" .1.3.6.1.2.1.2.2.1.5.2
          response is
          .1.3.6.1.2.1.2.2.1.5.2 = Gauge32: 0
          snmpget -v 2c -c "community name" -On "ip switch" .1.3.6.1.2.1.2.2.1.5.2
          response is
          • ilikejam
            • Oct 2008
            • 9
            Me Too!
            I'm getting this as well.
            I've switched on debug on the target system's snmpd, and it looks very much like the community string isn't being sent by zabbix in the SNMP GET, despite the community string being set to 'public' in the zabbix Item.
            Here's the snmpd log from a command line snmpget (which works OK and returns a sensible answer):
            Received 43 bytes from 10.27.4.153
            0000: 30 29 02 01  01 04 06 70  75 62 6C 69  63 A0 1C 02    0).....public�..
            0016: 04 75 71 04  8E 02 01 00  02 01 00 30  0E 30 0C 06    .uq........0.0..
            0032: 08 2B 06 01  02 01 01 01  00 05 00                    .+.........
            Received SNMP packet(s) from 10.27.4.153
              GET message
                -- SNMPv2-MIB::sysDescr.0
            Sending 89 bytes to 10.27.4.153
            0000: 30 57 02 01  01 04 06 70  75 62 6C 69  63 A2 4A 02    0W.....public.J.
            0016: 04 75 71 04  8E 02 01 00  02 01 00 30  3C 30 3A 06    .uq........0<0:.
            0032: 08 2B 06 01  02 01 01 01  00 04 2E 53  75 6E 4F 53    .+.........SunOS
            0048: 20 68 6E 75  6E 78 6A 65  74 30 31 73  20 35 2E 31     hnunxjet01s 5.1
            0064: 30 20 47 65  6E 65 72 69  63 5F 31 34  31 34 31 34    0 Generic_141414
            0080: 2D 30 39 20  73 75 6E 34  75                          -09 sun4u
            And here's what the zabbix snmp probe looks like:
            eceived 37 bytes from 10.27.4.153
            0000: 30 23 02 01  01 04 00 A0  1C 02 04 5A  A3 33 EF 02    0#.....�...Z.3�.
            0016: 01 00 02 01  00 30 0E 30  0C 06 08 2B  06 01 02 01    .....0.0...+....
            0032: 01 05 00 05  00                                       .....
              GET message
                -- SNMPv2-MIB::sysName.0
            Note the lack of 'public' in the request.
            This is zabbix_server 1.8.4 on Solaris 10, compiled against net-snmp 5.6 . I've tried net-snmp 5.6.1 (latest), but it's the same.
            Anyone got any ideas?
            Dave
            • captaincarisma
              • Mar 2011
              • 16
              response is
              response is
              The response is correct???
              • qix
                • Oct 2006
                • 423
                Yes, the response is correct.
                Replace "ip switch" with that ACTUAL ip adres of your switch
                With kind regards,
                Raymond
                • norms
                  • May 2011
                  • 14
                  Was an solution found for this
                  • ilikejam
                    • Oct 2008
                    • 9
                    I don't think so. I've not tried 1.8.6 on the server end yet though.
