Summing OID values
  • rhettich
    • Dec 2007
    Summing OID values
    I need to sum multiple OID values, for example given
    1.3.6.1.4.1.1372.1.4.2.1.5 =total TCP bytes
    1.3.6.1.4.1.1372.1.4.2.1.5 = total UDP bytes
    my target is total of TCP and UDP bytes
    How is this best accomplished ?
  • JBo
    • Jan 2011
    • 310
    You can do that with calculated items
    Regards,
    JBo
    • rhettich
      • Dec 2007
      Thanks JBo, I didnot see that paragraph before posting, problem solved , thanks!
