Hi!
I'm using zabbix 1.9.3 (alpha) which supports auto discovery of items.
Please suggest me how I can create calculated item based on autodiscovered items.
I was trying few times, but new item in result wasn't calculated.
Unfortunately autodiscovery not supported on FreeBSDs zabbix-agentd , therefore I'm using zabbix-agentd.conf UserParameter like this:
UserParameter=ufs_discovery,/sbin/mount -tufs | awk 'BEGIN{S="{\"ufs_discovery\":["} {DEV=$1; S=S "{\"{#FSMOUNTPOINT}\":\""$3"\",\"{#FSDEVICE\":\""D EV"\"},"} END{sub(/,$/,"",S); S=S "]}";print S}'
which returns JSON data with mountpoints (FSDEVICE meaningless here).
Zabbix server receive this JSON data and retrieve in next keys autodiscovered items:
vfs.fs.size["{#FSMOUNTPOINT}",free]
vfs.fs.size["{#FSMOUNTPOINT}",total]
vfs.fs.size["{#FSMOUNTPOINT}",used]
vfs.fs.size["{#FSMOUNTPOINT}",pfree]
vfs.fs.size["{#FSMOUNTPOINT}",pused]
etc.
Due to bug https://support.zabbix.com/browse/ZBX-2966 I cant create triggers for all disks to monitor free (percent) disk space. Therefore I want to create workaround like calculated item.
My calculated item is (it's second try):
Type: calculated
Key: free_space_percent_calculated.root
Formula: 100*(last("vfs.fs.size[/,total]")-last("vfs.fs.size[/,used]"))/last("vfs.fs.size[/,total]")
Type of information: Numeric (float)
and don't work.
I was tried another variant before (for all discovered items instead single variant above):
Type: calculated
Key: free_space_percent_calculated."{#FSMOUNTPOINT}"
Formula: 100*(last("vfs.fs.size[{#FSMOUNTPOINT},total]")-last("vfs.fs.size[{#FSMOUNTPOINT},used]"))/last("vfs.fs.size[{#FSMOUNTPOINT},total]")
I also tried other combinations with different quotes and quoting position, but nothing helped me.
Is it possible create calculated item, based on autodiscovered items?
etc.
Type: calculated
and don't work.
Type: calculated
