3 Questions
  • Eppi
    • Apr 2011
    • 16
    #16
    at this moment i see the "allowed host" input field. this could be the problem... but i get this parameter from two hosts.
    regards,
    paul
    • Bennie
      • Feb 2010
      • 73
      #17
      its setup per host once the template is applied to a host.
      • Eppi
        • Apr 2011
        • 16
        #18
        yes, great! 192.168.30.2 is working. but i get this item from 192.168.30.2 and 192.168.30.4, could be later more. can i use something like 192.168.30.* ?
        regards,
        paul
        • Bennie
          • Feb 2010
          • 73
          #19
          try dividing them with spaces or comma, not sure on that part.
          • Eppi
            • Apr 2011
            • 16
            #20
            thank you very much! i will test now and look if i still get the resolved messages every minute.
            regards,
            paul
            • Eppi
              • Apr 2011
              • 16
              #21
              it seem to work now without problems. thank you very much!
              best regards,
              paul
              • Bennie
                • Feb 2010
                • 73
                #22
                No problem, thats what forums are for
                Good luck with your future Zabbix use.
                • lisalin
                  • Apr 2011
                  Originally posted by Eppi
                  could be that i have the same problem like here?
                  regards, paul
                  i don't think so
