Monitor SMTP response time
  • assie
    • Apr 2011
    • 17
    Hi all,
    Iv used the web application thing with the scenarios to monitor the response times
    for HTTP. Now I want to do the same thing with SMTP. To connect to port 25
    and report back how long it took, and then graph it.
    Can this be done within Zabbix?
  • nelsonab
    • Sep 2006
    • 1233
    Yes it can. However you will need to write an external script to do it.
    RHCE, author of zbxapi
    • nelsonab
      • Sep 2006
      • 1233
      Hat tip to Jnx for pointing this out out in the IRC channel.
      You might also look into the item smpt_perf
      http://www.zabbix.com/documentation/...config/items?s[]=smtp_perf
      It's about 3/4 the way down the page.
      • assie
        • Apr 2011
        • 17
        smtp_perf sounds good, but is that windows?
        I tried to click the link but it gives me a permission denied..
        • Bennie
          • Feb 2010
          • 73
          assie,
          the link is a bit broken due to the []
          Try this one simple checks
          Look for smtp_perf
          Its not windows, its done from the zabbix server. Don't get mislead by the name perf
          • assie
            • Apr 2011
            • 17
            Originally posted by Bennie
            assie,
            Look for smtp_perf
            Thanks man, I found it, and its graphing happily, nice!
