The keys net.tcp.port and tcp,port using what commands to perform the check?
  • jrprado
    • Sep 2010
    • 28
    The keys net.tcp.port and tcp,port using what commands to perform the check? I searched in the sourcers and not found. I need that much of this information.
    Appreciate the help!
  • jrprado
    • Sep 2010
    • 28
    Nobody knows the command?
    The key net.tcp.listen know using the netstat command.
    What is to net.tcp.port? and tcp,port?
    Can anyone help me? Nobody knows the command?
    • untergeek
      • Jun 2009
      • 512
      I know this isn't an answer, but what if it isn't a unix command but a call to a kernel value or some such thing in /proc?
      • jrprado
        • Sep 2010
        • 28
        Please i really need a answer!
        • untergeek
          • Jun 2009
          • 512
          You could go through the C code. I'm pretty sure they don't use a unix command to do the check, but perform the checks by way of libraries with functions similar to unix binaries.
          Repeated differently: Unix binaries reference libraries to do these TCP checks. So does Zabbix. In other words the zabbix_agentd process is what is making the call, by using the linked libraries.
          $ strings /usr/local/sbin/zabbix_agentd | grep tcp
          /proc/net/tcp
          zbx_tcp_listen() Fatal error: unable to serve on any address. [[%s]:%hu]
          net.tcp.listen
          net.tcp.dns
          net.tcp.dns.query
          net.tcp.port
          net.tcp.service
          net.tcp.service.perf
          Like I said in my previous post, it seems that it can and does get some information from the /proc filesystem. Otherwise it's doing TCP calls directly using the aforementioned libraries.
          • jrprado
            • Sep 2010
            • 28
            untergeek, thank you very much!
            It is a way! I will do some research about it.
