I want to start zabbix_server deamon with other systemuser not 'zabbix'
  • karma.xiang@gmail.com
    • Apr 2011
    if the system user 'zabbix' does't created ,the zabbix_server daemon start faild:
    User zabbix does not exist
    In the zabbix_server.conf file, no parameter about the systemuser which with the zabbix_server daemon starts;
    In the src files ,I try to find some messaege like "User * does not exist",but no help;
    I want to start zabbix_server deamon with other systemuser not 'zabbix' Does somebody can help me ? thx
  • untergeek
    • Jun 2009
    • 512
    I believe that if you try to launch Zabbix as root, it will attempt to change the running user to zabbix.
    Have you tried to launch the zabbix_server or _agentd binaries as a user other than root?
