monitoring ppp0 (pppoe) status and ip
  • MADxHAWK
    • Apr 2011
    • 41
    im using an fli4l linuxbased router for my internetconnections. Because of the very small linuxversion (baseinstallation fits on a 1.44MB Floppy) and the low Diskspace zabbix_agent(d) wont run on it. So i can only gather data via snmp.
    What i want is to monitor the status of the ppp0 interface (DSL On-/Offline) but i dont have any idea how to get these infos from snmp.
    I can get the status of the router via a scriptcommand like
    cimon <host_ip> status pppoe
    which will either return OK Online or OK Offline. Is there any way to run this command from Zabbix server as item?
    greetz
    MAD
  • marcel
    • Oct 2010
    • 112
    how about zabbix_sender combined with crontab?
    Zabbix Certified Specialist for Large Environments since 12/2010
    • MADxHAWK
      • Apr 2011
      • 41
      Well i already thought about that soulution, but i thought maybe i could add a "Item-key" like system.run[command,<mode>] but the command / script wont run on the monitored host system, it would run on the zabbix serversytem. So zubbix could poll the data, instead of receiving it from a zabbix-sender runned by crontab. And Another problem, you can run a cron only every full minute, so thers no way to get data every 30 or 90 seconds.
      greetz
      MAD
      • marcel
        • Oct 2010
        • 112
        system.run needs zabbix_agentd to be running on the target host
        you can run zabbix_sender in an infinite shell script loop
        marcel
        • MADxHAWK
          • Apr 2011
          • 41
          Ok many thanks, will try this
