map elements are duplicated when imported
  • tfqzab
    • Apr 2011
    • 51
    hello, everyone. I am using zabbix applicance 1.8.4. Anyone come across this problem? When I import map from a xml, the map elements are dulplicated.
    I searched the internet and found this is a bug in 1.8.4, and it is fixed in 1.8.5.
    How can I upgrade zabbix appliance 1.8.4 to 1.8.5? I don't want to deploy a totally new 1.8.5 and import my datas into it. Or how can I fix the duplicating problem in 1.8.4?
    excuse me for my bad English. Anyone can help me? Thanks in advance!
  • alisson
    • Nov 2009
    • 70
    by the fact that it's an error in the interface, you need only change the interface. ie, exchange your /var/www/html (your home apache dir) and put the php files of 1.8.5 there. Configure the setup on interface and that is.
    Short, Recompile Zabbix binaries and update front-end PHP files.
    No database import or export is needed.
    __________________
    Alisson Oliveira
    [url]www.zabbix.com.br[/url]
    [url]www.unirede.net[/url]
    Porto Alegre - RS - Brasil
    • tfqzab
      • Apr 2011
      • 51
      thanks a lot, alisson. I'll try it.
