API, PHP, get macros filter problem.
  • maxlock
    • Mar 2005
    • 32
    Hi All,
    I'm trying to search the macros defined in a template for one with a matching value, I'm getting all the macros for the host returned instead of just one. Where am I going wrong? all the macros have unique values, is as though the filtering is broken?
    PHP Code:
    $macro_detail = ZabbixAPI::fetch_array('usermacro','get',array('filter'=>array('value'=>$my_value),'hostids'=>array($my_templateid),'extendoutput'=>1));
    Zabbix is 1.8.2.
    -Cheers Max
