Retrieving a value from a Web Test
  • mpureka
    • Apr 2011
    • 28
    I have an interesting scenario, where I would like to use Zabbix to fetch data from an external application.
    The application in question makes data available via HTTP request - if I connect to a properly formatted URL, it returns a bunch of values. Is it possible for me to use Zabbix to capture one or more of these values?
    So, for example, if I went to:
    TestServer.com is for sale. Contact the seller through NamePros to ask the price or make an offer. Interested in buying this domain name?
    And it returns:
    Status: OK
    Users: 10
    Is there any way that Zabbix can return the value 10?
  • richlv
    • Oct 2005
    • 3112
    definitely. exact approach would depend on some other factors like amount of values you want to retrieve and how long it takes to open such a url.
    possible solutions :
    1. use external checks on zabbix server to parse the page;
    2. use userparameters on the agent to parse the page;
    3. parse the page with a script and send values with zabbix_sender.
    • mpureka
      • Apr 2011
      • 28
      Right, so this is more of a job for an external check and less of a job for a web scenario. That's the path we're moving down now, performing a wget on the page and parsing the output.
      • richlv
        • Oct 2005
        • 3112
        just beware of external checks tying up zabbix pollers. userparameters might be a better choice, and if you have lots of values, script + zabbix_sender an even better one
        • mpureka
          • Apr 2011
          • 28
          Can you go into a little more detail on those alternatives?
          • richlv
            • Oct 2005
            • 3112
            http://www.zabbix.com/documentation/...ser_parameters
            http://www.zabbix.com/documentation/.../zabbix_sender
            • mpureka
              • Apr 2011
              • 28
              Resurrecting my own thread here as I'm finally getting around to trying to cut this over to user parameters; The documentation is quite clear on how to set up a user parameter, but seems to contain absolutely no information on how to actually retrieve the data from a user parameter as a Zabbix item.
              This seems like a crucial bit of information - once I've defined my user parameter in the agent config file, how do I actually access that data?
              • richlv
                • Oct 2005
                • 3112
                as any other zabbix agent item, using the key you specified in the config file
                • mpureka
                  • Apr 2011
                  • 28
                  Oh. I see. It didn't occur to me to think of the 'key' defined in the user parameter as the same as the 'key' that gets entered when creating an item.
