Formatting Value
  • antonie vonk
    • Jul 2009
    • 9
    Formatting Value
    Hi gents,
    I've got a question.
    Is it possible to format an Item value in zabbix instat of only giving a string for Units.
    Example.
    SNMP Temperature raw value is 188 or 189 or 190 or 191
    I have to use the multiplier of 0.1
    Temp. is 18.8 - 18.9 - 19.0 - 19.1
    But at 19.0 it shos only 19
    Can I format the value so it shows always ##.#
    Regatds Antonie
  • untergeek
    • Jun 2009
    • 512
    I don't think Zabbix can do that. It would involve altering the PHP code to display that format. I'm not sure anyone's going to do that, though you could.
