Map labels
  • mbconn
    • May 2011
    • 14
    Map labels
    is it possible to change the label on a map element dynamically.
    Basically, I'm monitoring a failover environment. At any time one of two load-balancers could be the "active" server, while the other is "standby". I'd like to denote which is currently active on the map if that's possible, i.e. as well as "OK" show "ACTIVE"? I can remotely detect which one is active relatively easily, but I can't figure out how to show that on the map?
    thanks
    Mike
  • richlv
    • Oct 2005
    • 3112
    you could have an item on each of them which would return ACTIVE/STANDBY. then use {host:item.function()} macro in the map element label to show host/cluster node status on the map
    • mbconn
      • May 2011
      • 14
      thanks for that, I'll give it a go and post here if I get it working.
      • mbconn
        • May 2011
        • 14
        Resolved
        thanks for that, exactly what I wanted. If it's of help to anyone else, the map label I use is:
        Test NginxB:{Test NginxB:nginx.active.last(0)}
        nginx.active is an item referring to an agent-side script which returns either Active or Standby.
        so the label on the map element is shown as either
        Test NginxB: Active
        or
        Test NginxB: Standby
        thanks again
        Mike
