Hi all,
I've been reading and searching through the forums and haven't found what I'm looking for so I figured I'd post and see if someone knows the answer.
I have a file that gets updated every 5 minutes and what I'd like to have is an alert happen if the time stamp on the file shows that it's older than 7 minutes.
I've tried creating the item and then a trigger but I'm not having much luck. One of the things that I think might be an issue is the Zabbix server is in another timezone, 2 hours ahead of the server that the file resides on, so I'm wondering if this may also be causing me an issue.
What I'm hoping is that someone can help with confirming how I should create the item and then the trigger .
Thanks very much for your help.
Cheers
Andrew
Cheers
Andrew
