Zabbix over WAN
  • markclark
    • Apr 2011
    • 70
    Zabbix over WAN
    Hi there,
    Zabbix works perfectly fine internally. Want to setup an agent to run on an external network and send the data back and be monitored.
    Ive setup the Zabbix Agent. Opened the firewall ports and tested them coming back into our office and they work fine.
    Within Zabbix i create a new Host but add the internal IP address of the client or external and setup port forwarding on their router/firewall back to the zabbix agent?
    thanks and think im getting myself confused somewhere along the line
  • Bennie
    • Feb 2010
    • 73
    If you are not running any VPN or Tunnels to make the external network part of yours you need to use the external ip and forward the ports. You can also use the agents in active mode. This makes them connect to the server and you don't need forwarding.
    • markclark
      • Apr 2011
      • 70
      ok thanks so much for clarifying that
      when you say you can use agents in active mode, do i need to change this under the triggers / items under the templates or would it be better for me to read up on that somewhere?
      thanks again.
      • Bennie
        • Feb 2010
        • 73
        its always good to read, but you need to change 'Type' when editing an item to "Zabbix agent active" from "Zabbix agent".
        You will also need to adjust the config file on the agent so it will retrieve items from the server to monitor. It can be found in the manual
        • markclark
          • Apr 2011
          • 70
          thanks, might go with the first option with the port forwarding as that worked straight away as trying to re-edit everything and testing might take some time and getting it to work again...
          what would you recommend if you have multiple clients without a VPN / tunnel to the LAN?
          thanks so much
          • markclark
            • Apr 2011
            • 70
            my other question would be what if you had 2 servers on the remote site.
            you setup agents on both and still leave default forwarding ports or have to open and setup new ports per / server / agent and then do the forwarding on the router/firewall?
            then how would you setup the hosts file?
            thanks.
            • markclark
              • Apr 2011
              • 70
              then how would you setup the hosts?
              thanks.
              • Bennie
                • Feb 2010
                • 73
                You need to forward a new set of ports for each server. You can still forward a port to the default agent port more then once but the external port needs to be different.
                1st server: 10050 > 10050
                2nd server: 10051 > 10050
                The external ports need to be configured on the zabbix server under the host settings "Zabbix agent port".
                • tomras
                  • Mar 2014
                  Sry to open this old thread
                  But Im trying to get this to work with different ports for more than one client outside LAN, is there any that can give dirrect me in a very basic way?
                  Tnx Tom
                  • markclark
                    • Apr 2011
                    • 70
                    Hi Tomras,
                    As Bennie said, all about the port forwarding / NAT on the firewalls and config.
                    • tomras
                      • Mar 2014
                      Originally posted by markclark
                      Hi Tomras,
                      Yes that I understand and I dont have any problem opening ports for the incomming connection, problem is when I try another port beside the standard port it just don't work? If someone had a working config for the client agent so I could compare with my settings it would be great, and settings for the host configuration, im stuck here
                      / Tom
                      • ingus.vilnis
                        • Mar 2014
                        • 908
                        / Tom
                        Hello Tom,
                        I would say that you have a port forwarding issue here. I don't know your exerience level in this but i would suggest you the following:
                        1) On router at your remote location set up port forwarding for each Host you want to monitor. It should go like this:
                        Host => External IP => Ext. Port => Internal IP => Int. Port
                        Comp.A => 87.230.xx.xx => 10062 => 192.168.1.2 => 10050
                        Comp.B => 87.230.xx.xx => 10063 => 192.168.1.3 => 10050
                        etc.
                        2) Please check your zabbix_agent.conf file on all the remote hosts to see if the port settings there match the ones you have entered in router (should be 10050 if you have not manually changed them)
                        3) On Zabbix frontend add the remote hosts by entering the External IP of your remote location and the correct External Port you have assigned for each host.
                        4) Check if the hostnames in configh match correctly for all devices you monitor.
                        Hope this helps!
                        BR
                        Ingus
                        • aib
                          • Jan 2014
                          • 1615
                          Well, it looks a little bit complicated...
                          Let's start the explanation with some numbers.
                          We have Main Office where Zabbix server with internal IP 1.1.1.1 and external IP 250.250.250.250.
                          Zabbix server send request to zabbix agent using the port 10050 and receive data from agent on port 10051
                          Then we have Branch Office where one FireWall and two servers were installed.
                          FW has the External IP 100.100.100.100.
                          Server1
                          - internal IP 2.2.2.2
                          - external IPort 100.100.100.100:11112
                          Server2
                          - internal IP 2.2.2.3
                          - external IPort 100.100.100.100:11113
                          FW port forwarding rules:
                          - all external request which are going to 100.100.100.100:11112 translate to internal 2.2.2.2:10050
                          - all external request which are going to 100.100.100.100:11113 translate to internal 2.2.2.3:10050
                          Zabbix Server Frontend configuration:
                          host Server1:
                          - Agent Interfaces:
                          - IP Address: 100.100.100.100
                          - port: 11112
                          host Server2:
                          - Agent Interfaces:
                          - port: 11113
                          You don't have to change any default setting in zabbix_agent.conf because there are the FireWall who cares about translating requests and ports to correct numbers.
                          Only one thing which has to be configured correctly is the IP address of Zabbix Server.
                          First, check if you have any access from the agent side to server:
                          # telnet {ip_of_zabbix_server} 10051
                          Trying {ip_of_zabbix_server}...
                          Connected to {ip_of_zabbix_server}.
                          Escape character is '^]'.
                          and if you get the empty line and server will wait until your input - you have a connection!
                          Hit any key and close connection.
                          Then, write {ip_of_zabbix_server} in zabbix_agent.conf file
                          Server={ip_of_zabbix_server}
                          If you cannot connect to Internal IP of your server - try to use External IP.
                          If it doesn't work - check/create Port Forwarding rules for the FW which protect the network where your Zabbix Server lives.
                          Your goal is to create/test a connection between each zabbix_agent and zabbix_server.
                          I hope that you still have a cold brain and this complicated things did not brought you crazy.
                          Sincerely yours,
                          Aleksey
                          • aib
                            • Jan 2014
                            • 1615
                            wow!
                            so many explanation for PAT and NAT stuff
                            Sincerely yours,
                            Aleksey
                            • markclark
                              • Apr 2011
                              • 70
                              #15
                              are you mapping as an example below?
                              10050 -> SERVER 10050
                              10051 -> SERVER 10050
                              10052 -> SERVER 10050
                              or
                              10051 -> SERVER 10051
                              10052 -> SERVER 10052
                              if you are mapping like the second option you need to make sure its listening on the right port in the config file on the server / device thats being monitored.
                              You can run a simple telnet test on the port outside of the organisation to test if its listening or not.
                              I prefer the first option of doing things.
