Can't monitor OpenVPN tun0?
  • simonmd
    • Mar 2011
    Hello all..
    I'm trying to monitor an OpenVPN tun0 network interface with the following key:
    net.if.out[tun0,bytes]
    However, I am unable to recieve any data since it shows up as "Not supported"
    I have been able to monitor this OpenVPN installation with Zenoss successfully before, and the tun0 interface shows up correctly on an 'ifconfig'.
    Is this a bug? Does anybody have any success stories monitoring OpenVPN that they could share?
    Thanks!
    Simon
  • ghoz
    • May 2011
    • 204
    maybe the agent is started before the tunnel is setup ?
    I'm guessing the agent lists interface at startup and don't see the openvpn one ?
    have you tried restarting the agent after the openvpn come up ?
    • jpdborgna
      • Jan 2013
      Where you able to solve this?
      I'm trying to do the same.
