Problem with bar reports
  • alvaroarb
    • Feb 2011
    • 10
    Hi to all
    I'm having an issue with a bar report, when i try to generate report based on "compare values for multiple periods" i can't select any item, i select the needed group and hosts to compare, set the time frame and click on the button "select" in order to select the requiested item to compare, the popup window with the items list appears but i click on the desired item and nothing happens, the popup window just stays there and it should dissapear and the item be added ... i check the apache's acceslog and errorlog and don't see anything happening there when i click on the desired item ... what can be happening here?
    I'm using Zabbix 1.8.5 on top of a RHEL 5.6 64 bits with stock httpd 2.2.3-45 and mysql 5.0.77-4
