I just finished setting up web monitoring on our new Zabbix install and I am having a problem with what I believe to be false positives.
It is very simple monitoring:
One step
No authentication
30 Second update interval
30 Second timeout
Searching for one string of text
Status of 200
I have a trigger set up with:
{Web Server:web.test.fail[site].last(#4)}>0
To my understanding, this means that this trigger should go off if there are 4 consecutive failed tests. I'm running into two issues with this.
One, the web server seems to be failing tests randomly and for no particular reason. Occasionally a single test will fail, and I can't really find out any information as to why. I can't find anywhere in a log as to which condition wasn't met. When I look at "response code", I see 200s across the board, so I have no clue why this is failing.
Secondly, even though these failures are random, single events, I seem to get a notification after every one - not after 4 consecutive. Even the notification I get says the last value was 0.
Does anyone have any advice on tracking down what exactly is causing these failures?
One step
No authentication
30 Second timeout
Status of 200
