libnetsnmp.so.10 not found
  • wikisb
    • May 2011
    • 64
    hi all!!
    i tell you what i have done. first of all i installed postgres, php, apache with net-snmp 5.3.2 from rpm all else from tar.gz. zabbix worked fine exept to reach certains OID's(like average loads, 1,5 15 min). then i desinstalled net-snmp and downloaded it from tar.gz a newer version. i runned again zabbix and it worked fine for 5 min i could monitore certains OID's i couldn't before but after 5 min it stoped working. so i executed again ./zabbix_Server but it prompted this: "libnetsnmp.so.10 cannot open it, no such file or directory" i do ldd to know where zabbix goes to find the libraries but this especific one it doesn't exists. i tried to download it but i can't find it. can anyone help me please!!!
    well finally i used yum install (i don't like using it) libnetsnmp.so.10 and it installed me the net-snmp-libs. so i moved the libnetsnmp.so.10 where zabbix can find it and now all works fine!!
    sorry about bother you
    thanks!!
