monitor 1 system using SNMP and Zabbix Agent
  • npereira
    • Jun 2011
    Started working with Zabbix for about a week now, and love this....
    I monitor several hosts which one is Elastix, and Asterisk based PBX. For this host, I want to monitor SNMP using port 161 and using a specific template which works fine, yet I also want to monitor zabbix_agentd on 10050.
    How can you monitor multiple service on 1 target system?
  • ghoz
    • May 2011
    • 204
    juste create/use items with different types
    use snmp agent items for... snmp ,
    and zabbix agent items for ... agent queries
    as long as you don't have colliding item keys, you can also create templates and link your templates to your hosts (maybe a template_asterisk whith your specific snmp items, and a linux one with the generic agent items)
    • npereira
      • Jun 2011
      But the problem is the host.
      When i click hosts, to see all my hosts, i cannot add port 161 and 10050 in the port section, it only takes 1 port not multiple
      • ghoz
        • May 2011
        • 204
        zabix agent port is at the host level
        snmp port / community is at the item level when you choose type SNMP agent.
        you can define a macro {$SNMP_COMMUNITY} or whatever at the host level and use it as community for your items if you want, it should work for snmp port the same way (I didn't test)
