i am using zabbix 1.8.4 with debian squeeze and have a situation where i need to check that if two IPs are live then zabbix will send an email alert. I have tried using the actions with 'and' on the action by adding both hosts but it does not work. I am using icmpping in simple checks
{Template_good_ping:icmpping.last(10)}=1 which gives an ok trigger when down and problem when up
can anyone help
Regards
can anyone help
Regards
