Maintenance mode from CLI
  • dpbaker57
    • Aug 2010
    • 33
    We are monitoring many websites and their servers. During a software release we also include windows patching. Our software releases are almost completely scripted, in Windows batch files most of the time. Our Zabbix server runs Linux. I figure I can use the Cygwin ssh client with keys to be able to run a shell script on the Zabbix host to disable the monitors affected by the software release.
    What I need is help on how to build the shell script to disable, or preferably place in maintenance mode, the monitors while the release is happening. Of course I will need a script to undo this at the end of the release.
  • ghoz
    • May 2011
    • 204
    you are looking for for zabcon, it's a command line addon that uses the zabbix API.
    however, I'm not sure it handles maintenance mode...
    • nelsonab
      • Sep 2006
      • 1233
      In zabcon you will need to use the raw.api call:
      raw.api maintenance.create hostids=1234,5678 name="Weekly Maintenance" maintenance_type=1 timeperiods={timeperiod_type=3 start_time=82800 period=7200 every=1 dayofweek=6}
      I haven't tested the above, but I adapted the example. That should create a maintenance window which runs every Saturday at 2300 for two hours. Unfortunately the documentation is a little light in this area.
      RHCE, author of zbxapi
      • nicolassd
        • Jul 2011
        Hi Nelson
        I test with this:
        raw api maintenance.create hostids=10176 name="Test Maintenance" maintenance_type=1 timeperiods={timeperiod_type=0 start_time=82800 period=7200}
        Result:
        Unexpected parameter "="
        please you would have some other example?
        Thank you.
        Nicolas.
