Issues when monitoring SAN MSA2000x
  • sheen
    • Apr 2009
    • 24
    Hi all,
    I have an issue for monitoring an MSA2000x.
    I got the MIB and it's working but the problem is I'm getting value in string format.
    I don't know why, but HP decide to return a string instead of an integrer, so I'm not able to monitor the value.
    For example :
    snmpget -v 2c -c public 192.168.XXX.XXX experimental.94.1.8.1.6.32.128.0.192.255.218.15.56 .0.0.0.0.0.0.0.0.5
    Give me as output :
    SNMPv2-SMI::experimental.94.1.8.1.6.32.128.0.192.255.218. 15.56.0.0.0.0.0.0.0.0.5 = STRING: "Onboard Temperature 1 (Controller Module A): 35C 95F"
    So I have to use cut / sed /awk to get value only (35 in this example)
    It work I can get the value alone using parsing command line, but now I don't understand how to monitor this value in Zabbix.
    Is there a simple way to create a new element in template which is a result of a command line ?
    Thank you for futures replies.
  • sheen
    • Apr 2009
    • 24
    No ideas ?
