Performance Monitor & Active Agents
  • nabberuk
    • May 2010
    • 82
    Quick question, i've had a search on these forums but couldnt find an answer. How do i go about monitoring items in performance monitor within windows using an active check agent.
    Would i need to add userparameters to the agents conf file?
    thanks
  • ghoz
    • May 2011
    • 204
    you have to search the Fine Manual :http://www.zabbix.com/documentation/...fic_parameters ,
    http://www.zabbix.com/documentation/...mance_counters, and http://www.zabbix.com/documentation/...iguration_file.
    Basicaly you can
    • tell zabbix server to get the perf counter from the agent : item =perf_counter["myperfcounter"]...
    • tell the aggent to collect and agregate the data for later use by the server... item=younameIt on the server, and a perfcounter=youNameIt,"myperfcounter",duration... on the agent config file,
