hi all again!!
i googled and found this old thread http://www.zabbix.com/forum/showthread.php?t=5666 about monitoring udp ports. i wonder if with newer versions of zabbix it is possible to do it in a simple way, with simple check it seems impossible.
as i see (i use SNMP, not zabbix_agent, for most of my monitoring) i will need to make a Server side script or a wrapper around fping as "James Wales" said.
any suggestions ???
Thanks!!!
any suggestions ???
Thanks!!!
