WEB Monitoring - Need help with expression
  • xcalibur
    • Apr 2011
    • 40
    Hey,
    I'm monitoring the availability of some websites. Since I'm getting some occasional timeouts I'd like Zabbix to fire off the trigger only after the third failure. So I set it up as follows:
    {URLS:web.test.fail[website.com].max(#4)}>3
    I'm not very sure about this. What does "{URLS:web.test.fail[website.com].max(#4)}" actually return? A true or false?
  • Yello
    • Apr 2011
    • 309
    I don't use this style of trigger but I believe Max(#4) will return the largest of the last four values received.
    Regards,
    David
    • ghoz
      • May 2011
      • 204
      http://www.zabbix.com/documentation/...g#web_scenario
      This item keeps number of failed step of the scenario. If all steps are executed successfully, 0 is returned.
      Item key: web.test.fail[Scenario]
      Type: integer
      I would use a
      {URLS:web.test.fail[website.com].min(#4)}#0
      meaning 4 tests out of 4 had at least a failed step.
      On the other hand, your site is failing every fourth request, you'll never see it...
      you could add some kind of failsafe count : if there is that much failure in the last 20 checks , ring a bell...
      you 'd have to create a new trigger or add to the existing one something like
      OR {item.count(#20,0,”gt”)} > 4
      • Davidus
        • Dec 2010
        • 281
        My condition looks like this
        {HOST:web.test.fail[SERV].min(#15,0)}#0
        I`m doing checks once in 5 minutes, so if after 15minutes (3 checks) problem still exists trigger fires up
        Hope this helps
        • xcalibur
          • Apr 2011
          • 40
          I would use a
          It should actually be a whole lot simpler than that:
          {URLS:web.test.fail[website.com].MAX(#4)}#0
          If 4 fails occur the trigger will fire.
          I just tested and it works great!
          Thank you guys alot!
          • Yello
            • Apr 2011
            • 309
            That will be a mistake I think. What that statement says to me is that if the highest of the last 4 checks is not equal to 0 then fire. Using Min() is better because that implicitly means that all of the checks in the window of data have breached the threshold.
            Also, do you really want a threshold of zero? You showed a different threshold level in your first post.
            Regards,
            David
            • ghoz
              • May 2011
              • 204
              the return value is the failed step, 0 if everything is OK
              so using 'max' in this context means that if even one out of 4 tests fail => trigger fires, and get back to normal when 4 tests in a row are OK
              using min as i suggested would do the oposite : if 4 tests fails => trigger fires, when the scenario succeeds for the 1st time => send an OK ...
              depending on what you need, pick your choice
              • ghoz
                • May 2011
                • 204
                Hope this helps
                Be careful, you want to use min(900) an NOT min(#15) !
                using the '#' means last 15 checks => 75minutes of errors befor your trigger alerts you!
                your boss may not be happy :-)
                Last edited by ghoz; 11-08-2011, 09:14. Reason: min(15) => min(900) (time is in seconds, not minutes, duh...
                • Davidus
                  • Dec 2010
                  • 281
                  Be careful, you want to use min(15) an NOT min(#15) !
                  I`m doing checks every minute and if after 15 minutes (15 checks) problem still exist trigger fires up… sorry for inconvenience
