How to show software-generated events
  • linuxgurugamer
    • Oct 2010
    • 68
    How can I have a program generate an event to be shown on the dashboard?
    Thanks in advance.
    JBB
  • ghoz
    • May 2011
    • 204
    create a fake host (or use an existing one),
    create an fake item, type zabbix trapper
    create a trigger on that item for some magic value a number a string, pick your choice
    use zabbix_send to send the magic value when you need it.
