How not display warning if some critical trigger exists
  • menkovich
    • Jul 2011
    I have 2 triggers, for example "Disk usage /home < 10Gb" (warning) and "Disk usage /home < 5Gb" (critical). How not display warning, if critical already activated.
  • Davidus
    • Dec 2010
    • 281
    First trigger:
    "Disk usage /home < 10Gb" and "Disk usage /home > 5Gb" (warning)
    Second trigger:
    does that answers your question?
    • menkovich
      • Jul 2011
      Yes, thanks!
      • mirddin
        • Nov 2013
        • 22
        Yes, but no
        In such case when critical trigger switches on the contact person receives two notifications (Warning UP and Critical Down). Surely we can send only Critical notification, but in the triggers list user still see excess Warning messages.
        Have you implemented two-steps trigger type in Zabbix 2.4 version?
        thanks!
        • aib
          • Jan 2014
          • 1615
          Take a look on trigger dependencies.
          Warning trigger can be dependent on Critical trigger and you will have a Warning alert only(!) if Critical trigger is NOT active.
          Sincerely yours,
          Aleksey
