monitor TCP connections
  • wikisb
    • May 2011
    • 64
    hi all!
    i would like to monitor the tcp connections in any host but i don't know how to do it. i only use SNMP. i had a look to the TCP-MIB and google but nothing...
    i guess that you have to do something with the tcpConnTable OID: 1.3.6.1.2.1.6.13. but i don't manage to solve this issue.
    Thanks!!
  • caraconan
    • Oct 2012
    I'm playing a bit with this.
    I cloned 'Template SNMP Interfaces' and adapting to this SNMP MIB.
    My current problem is how to access to 'TCP-MIB::tcpListenerProcess.ipv4' indexes:
    $ snmpwalk -v 2c -c jj.com test-5.dev TCP-MIB::tcpListenerProcess.ipv4
    TCP-MIB::tcpListenerProcess.ipv4."0.0.0.0".22 = Gauge32: 0
    TCP-MIB::tcpListenerProcess.ipv4."0.0.0.0".111 = Gauge32: 0
    TCP-MIB::tcpListenerProcess.ipv4."0.0.0.0".10050 = Gauge32: 0
    TCP-MIB::tcpListenerProcess.ipv4."0.0.0.0".43430 = Gauge32: 0
    TCP-MIB::tcpListenerProcess.ipv4."0.0.0.0".60458 = Gauge32: 0
    TCP-MIB::tcpListenerProcess.ipv4."127.0.0.1".25 = Gauge32: 0
    $ snmpwalk -v 2c -c jj.com test-5.dev TCP-MIB::tcpListenerProcess.ipv4.\"0\.0\.0\.0\"
    TCP-MIB::tcpListenerProcess.ipv4."0.0.0.0" = No Such Instance currently exists at this OID
    I'll post here my progress.
    Regards.
    Javier
    • alledm
      • May 2012
      • 84
      I use iptstate to count tcp connections.
      just create a UserParameter like
      UserParameter=iptstate[*],sudo iptstate -1 |  awk '$$3 == "$1" && $$4 == "$2" { total = total + 1 } ; END { print total }'
      Load the iptstate modules
      modprobe nf_conntrack_ipv4
      modprobe nf_conntrack ipv6
      install iptstate and give SUDO permission to zabbix to run it.
      Use it like
      zabbix_agentd --test iptstate[tcp,ESTABLISHED]
      • BDiE8VNy
        • Apr 2010
        • 680
        Another way to gather current tcp information might be (not tested, written from memory):
        UserParameter=proc.net.tcp.count.established,/bin/grep -Ec '[0-9A-F]{8}:[0-9A-F]{4} [0-9A-F]{8}:[0-9A-F]{4} 01' /proc/net/tcp
        UserParameter=proc.net.tcp6.count.established,/bin/grep -Ec '[0-9A-F]{32}:[0-9A-F]{4} [0-9A-F]{32}:[0-9A-F]{4} 01' /proc/net/tcp6
        UserParameter=proc.net.tcp.count[*],/bin/grep -Ec '[0-9A-F]{8}:[0-9A-F]{4} [0-9A-F]{8}:[0-9A-F]{4} $1' /proc/net/tcp
        UserParameter=proc.net.tcp6.count[*],/bin/grep -Ec '[0-9A-F]{32}:[0-9A-F]{4} [0-9A-F]{32}:[0-9A-F]{4} $1' /proc/net/tcp6
        # connections established
        zabbix_agentd --test proc.net.tcp.count.established
        zabbix_agentd --test proc.net.tcp6.count.established
        # tcp sockets listening
        zabbix_agentd --test proc.net.tcp.count["0A"]
        zabbix_agentd --test proc.net.tcp6.count["0A"]
