Hi everyone,
I have a host with a zapcat monitored java application running, and I'd like to get the heap memory usage related to this app, but I can't figure out what is the JMX query the agent has to execute
So I have to use JMX on Memory MXBean , the HeapMemoryUsage attribute is a MemoryUsage object, so I can't directly use it. I'd like to get only the 'use' attribute of HeapMemoryUsage.
In my item, I tried with the following key :
jmx[java.lang:type=Memory][HeapMemoryUsage][Used]
(with numeric float type)... but I don't get any value.
What is the key to use to make it work?
