Duration of OK trigger
  • punksp
    • Mar 2010
    • 12
    Good morning!
    I use the Monitoring/Trigger to view what is happening. But when we recover a trigger (trigger goes from Problem to OK) it lasts 30 minutes to disapear.
    There is any way to make decrease this time?
  • Rob
    • Sep 2010
    • 18
    you need to edit the php file include/defines.inc.php
    Fairly near the top you should see the following two parameters:
    define('TRIGGER_FALSE_PERIOD', 60); // 1min, 0 - disable - time triggers display as OK after recovering
    define('TRIGGER_BLINK_PERIOD', 60); // 1min, 0 - disable - time triggers blink for after changing state
    You can use these values to alter the behaviour in the triggers screen. The first one is the one you want. As you can see I've changed it to 60 seconds so that our large display of active triggers in the office isn't cluttered with problems that have been resolved.
    • punksp
      • Mar 2010
      • 12
      Many Thanks!!!
      Many thanks! Works perfectly!!
