i use snmp in my items in order to know the bandwith, can i use the formula field with snmp on two different machines?
i tried to write a new item with {proxy2:ifInOctects.1.last(0)}+proxy1:ifInOctects. 1.last(0)} in the field expression, but it doesn't work
Reason: more information
