SLA and Web monitoring scenario
  • lbast
    • Jul 2011
    Is it possible to use the outcome of a Web Monitoring scenario
    to calculate the SLA instead of a trigger ?
    Kind regards,
    Luc
  • loalvares
    • Jun 2011
    • 35
    as I see...
    Its not possible because triggers shows if an error has occurred.
    Web monitoring only shows a web environment test.
    you can use a trigger to web monitoring, like response time, and use it on SLA.
    regards,
    Leandro
    • Hboris
      • Jun 2022
      • 12
      Hello there,
      Can you be more precise on how to use response time to calculate SLA please?
      I have a web page to monitor and i monitor my server response time.
      The SLO is 99% of response time must be UNDER 3 sec for example.
      How can i tell zabbix to calculate SLA based on the response time instead of downtime ?
      Thanks for you help.
