How do I identify unsupported items?
  • pierre.naude
    • Aug 2011
    Our Zabbix server is reporting via the dashboard that there are a couple of unsupported items.
    Other than trawling through all the configured host items, is there a report or some quick view of which items are problematic?
    I've managed to eliminate most of the problems by checking all the configured items (a major pain when you have a numbers of hosts) and the logs are not reporting anything but I cannot find the last 2 problems....
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    You may go to the list of items, click on Filter and select only "Status: Not supported" there.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • pierre.naude
      • Aug 2011
      Thanks, I didn't know that...
      Question though - I have ~ 100 hosts
      Is the only way for me to go into each host individually and filter to find unsupported items, or is there a way to filter only hosts that have unsupported items (the current hosts page filter does not appear to support that)?
      • ufocek
        • Aug 2006
        • 161
        No, you can select any host and go to the items, next click filter and you see advanced filter options (host group, application etc).
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          I does support it! Just remove pre-set host name (Host=<nothing>) in the filter and press Filter link.
          Alexei Vladishev
          My Twitter
          • pierre.naude
            • Aug 2011
            My apologies gents, that should have been obvious.
            Many thanks for your quick responses!
