Monitoring switch 3com 4200 in zabbix
  • idhakal
    • Jul 2011
    • 10
    Hi all,
    I am very new in zabbix. Does anyone have any idea how to monitor switch 3com 4200 in zabbix. I have already installed templates for this switch in zabbix and now I dont know the next step to follow.
    Thanking in advance
    Ishor
  • bcarpio
    • Jun 2008
    • 96
    Do This
    1) Change SNMP Community String In Template
    - Configuration >> Templates >> 3Com Template 4200
    - Click Items
    - Select every item in the template
    - Select from the dropdown "Mass Update"
    - On the mass update screen click "SNMP community"
    - It will say public change it to the community string you have on your switches
    2) Once that is completed, then make a new host
    - Configuration >> Hosts
    - New Host
    - Put in the info about the host such as IP, etc..
    - Add Template >> 3Com Template 4200
    Done
    • idhakal
      • Jul 2011
      • 10
      hi bcarpio,
      Thank you very much for your help. I really appreciate your help. Can you please tell me how can i find community string of the switch?
      Thanking you
      idhakal
      • bcarpio
        • Jun 2008
        • 96
        Reference Hardware Guide
        For that you need to reference the manual from your switch manufacturer, its probably public by default, I'd try that. If it doesn't work log into the switch and make sure SNMP is enabled.
        • Leandroc
          • Feb 2023
          Hi all, I´m new in Zabbix and need to add a 3COM 4210 (Zabbix 6.2) but I don´t see that in the template list. Where can I obtain that? Thanks in advance for the info. Regards.
