I have a task to monitor a 2008 R2 / 2008 R2 Sql Failover cluster using Zabbix. The only way I have been successful in monitoring failover in a Windows 2003 environment was to monitor the event logs and when an event Id was reported to the evt log, setup a trigger for it and alert the proper team that the cluster had failed over to a new node. I am currently trying to do this on a 2008 r2 server, but here is the catch: The events are logging into a log named "Microsoft-Windows-FailoverClustering/Operational". I have successfully been able to get latest data on the System and Application logs, but not this log. I have tried to see if there is a nested way windows is saving this log file such as saving it in the system log and via event viewer saving it as Microsoft-Windows-FailoverClustering/Operational log, but my searches for such info have come up dry.
Has anyone been successful in doing this?
Here is an excerpt from the Agent log file that I have been troubleshooting with:
5632:20110810:151410.158 Starting Zabbix Agent. Zabbix 1.8.5 (revision 19047).
3028:20110810:151410.162 agent #0 started [collector]
5512:20110810:151410.162 agent #1 started[listener]
1456:20110810:151410.162 agent #2 started[listener]
6272:20110810:151410.162 agent #4 started[listener]
6468:20110810:151410.163 agent #3 started[listener]
7056:20110810:151410.163 agent #5 started [active checks]
7056:20110810:151610.884 Can't open eventlog 'Microsoft-Windows-FailoverClustering/Operational' [The operation completed successfully.]
7056:20110810:151610.884 Active check [eventlog[Microsoft-Windows-FailoverClustering/Operational]] is not supported. Disabled.
copy of Conf file if needed:
Server=10.xx.xx.xx
ServerPort=10051
Hostname=xx-xx-xx
ListenPort=10050
StartAgents=4
EnableRemoteCommands=1
DebugLevel=3
LogFile=C:\zabbix\Zabbix_agentd.log
Timeout=5
UserParameter=uLastWinUpdate,cscript.exe /nologo "c:\zabbix\uLastWinUpdate.vbs"
Key being used in Item:
Server=10.xx.xx.xx
ServerPort=10051
Hostname=xx-xx-xx
ListenPort=10050
StartAgents=4
DebugLevel=3
Timeout=5
