I've succesfully configured my zabbix setup with Openldap authentication. So far so good!
I've then tried to setup ldap over ssl, but the test fails giving these two errors:
I kept the same configuration as the ldap without ssl, just changing the port to 636 and the uri to ldaps://...
I extracted the ldap server certificate with openssl s_client, taking care of copying the cert part (from and including ---begin certificate--- to and including ---end certificate---) to a .pem file, and placing it in /etc/ssl/certs/. At this point, I ran "c_rehash".
I can telnet to the ldap server on port 636, so it doesn't seem a firewall problem.
That's all I did. Is there some step I'm missing?
I can't seem to find a guide on how to configure openldap over ssl and zabbix.
Thank you!
Zabbix 1.8.5 on ubuntu server 10.04
Openldap on ubuntu server 10.04
ldap_bind(): Unable to bind to server: Can't contact LDAP server[/usr/share/zabbix/include/classes/class.cldap.php:114] LDAP: cannot bind by given Bind DN
Thank you!
