Delaying triggers
  • Huy Dinh
    • Jan 2006
    Delaying triggers
    I would like to have triggers only trigger after e. g. the 3rd time a trigger condition is true. Since last doesn't take any parameters, I can't check that using last(2), for example.
    Any ideas how to solve this?
  • cameronsto
    • Oct 2005
    • 148
    The new feature in in the Beta7 announcement titled "Support of #N in parameters of trigger functions." should accomplish what you're wanting.
    -cameron
    • sauron
      • Jan 2005
      • 215
      create complex trigger and use in expression agregate function.
      i.e. i.m use trigger with 5 min delay.
      • Huy Dinh
        • Jan 2006
        Okay, that works. Thanks a lot.
        One more thing: I have some items that are checked every 15 minutes. Is there any way to have those items checked every minute, iff the previous check reached a certain threshold and have that item checked every 15 minutes, when it returned below the threshold?
        • bbrendon
          • Sep 2005
          • 873
          Sounds like it could be useful, but no. Maybe add it as a feature request. sf.net/projects/zabbix/
          Unofficial Zabbix Expert
          Blog, Corporate Site
