Setting up Web Step
  • avashishtha
    • Aug 2011
    Setting up Web Step
    I am trying to setup a simple Web Step using post information and keep getting an error. "Failed on "Log in" [2 of 2] Error: Page did not match" I was following the steps listed in the Zabbix monitoring book, Heres what i have right now.
    Application : WebURLMon
    Authentication : None
    Update : 60
    Agent : Lynx....
    Status : Active
    Variables :
    {user}=<actual username>
    {password}=<actual password>
    Steps :
    1) First page - it works fine
    2) Name : Log in
    URL : https://www.openstreetmap.org/login
    Post :
    username ={user}&password={password}
    Timeout = 15
    Required = home
    Status Codes = 200
    I am fairly new to Zabbix and we are testing the product right now to see whether it will be sufficient in our environment or not. I appreciate any help on this.
    Thanks!
  • forlinuxsupport
    • Oct 2005
    • 39
    Try remove the "Required=home" line - it might be failing because it can't see that word on the page.
    Are you sure your POST line is correct ?
    Try run your web check line using curl on the command line - does it work there ?
