Graph graph title scaling
  • joedson
    • Jul 2011
    • 19
    Hello guys,
    Does somebody know how to set up
    the size (the font) of graph title bigger?
    Thanks in advance!
  • richlv
    • Oct 2005
    • 3112
    not really (without hacking php).
    • joedson
      • Jul 2011
      • 19
      Richlv, do you know wich specif part of the
      php (or other) source code, I could to change?
      Thanks!
      • richlv
        • Oct 2005
        • 3112
        sorry, i don't know that right now without additional investigation. a quick search reveals http://www.zabbix.com/forum/showthread.php?t=15378 - you could take a look at that patch and figure out where it changes the font scaling, maybe
        • joedson
          • Jul 2011
          • 19
          Richlv, I have looked at this, unfortunately
          its doesn't helped; looking at that post I only
          can change the size of legend.
          I have looked for the string "fontsize" inside
          the files (with the command grep -ir fontsize ./);
          into zabbix php frontend directory, but once again,
          I didn't found how to change the size of title.
          Thanks anyway!
          • joedson
            • Jul 2011
            • 19
            Guys,
            I discovered that that function wich write
            the texts in the graphs, is: function imageText($image, $fontsize, $angle, $x, $y, $color, $string); which is in php script graphs.inc.php;
            that is inside the directory /.../zabbix/include/graphs.inc.php
            So I made a change that source code in this function,
            adding this:
            function imageText($image, $fontsize, $angle, $x, $y, $color, $string){
            $gdinfo = gd_info();
            //Search for the paterner wich are at the graphs title
            //If add
            if(strstr($string,"(") && strstr($string,")") && strstr($string, ":")){
            $fontsize = 16;
            So a I recieved the expected result, as show in the
            pictures below:
            Graph before change:
            Graph after change:
            PS: I searched for for all php scripts and
            classes which call the funciton imageText
            and after change the parameter fontsize;
            I get change in everything less int the title.
            Does somebody know a better solution?
