Change Trigger Severity Names
  • ke_sheng_jie
    • Aug 2011
    • 40
    Does anyone know a way to change the trigger severities? We're moving from Nagios to Zabbix and would prefer to rename the High severity to Critical to match what we're used to.
    I tried looking in the database, but the severity is stored as a number. I searched through the code for the web GUI, but wasn't sure what needed to change and if it would change it throughout the system (including in emails sent).
    This would be a nice feature addition to the web GUI.
    4
    Yes
    75.00%
    3
    No
    25.00%
    1
    Don't Care
    0.00%
    0
  • CeeEss
    • Nov 2007
    • 103
    Edit the appropriate locale file in (zabbix_web_root)/include/locales/[your_locale).inc.php and redefine the severity variable mapping to something that more closely matches how you use severities: Changes will be reflected throughout Zabbix immediately (perhaps after a page refresh). In include/locales/en_gb.inc.php, they are set by default to:
    'S_NOT_CLASSIFIED'=> 'Not classified',
    'S_INFORMATION'=> 'Information',
    'S_WARNING'=> 'Warning',
    'S_AVERAGE'=> 'Average',
    'S_HIGH'=> 'High',
    'S_DISASTER'=> 'Disaster',
    I change them to something more meaningful (to me).
    'S_WARNING'=> 'Attention',
    'S_AVERAGE'=> 'Warning',
    'S_HIGH'=> 'High',
    'S_DISASTER'=> 'Critical',
    "DISASTER" in particular seems a little "over the top" .
    BTW: There are other definitions in the locale files that can achieve some form of UI personalisation, such as replacing instances of Zabbix with your company name.if you're exposing the UI to partners/clients. Be sure to make a note of any changes as the locale files will be overwritten when you upgrade the frontend along with server in the future.
    • ke_sheng_jie
      • Aug 2011
      • 40
      Thanks!
      That was just what I needed.
      • qix
        • Oct 2006
        • 423
        On the ZabConf I believe Alexei or Richlv noted that this will be easily configurable in Zabbix 2.0 via the Webgui.
        With kind regards,
        Raymond
        • ke_sheng_jie
          • Aug 2011
          • 40
          Email Severities
          This doesn't seem to change the severity names in emails sent when using the {trigger.severity} macro. Any idea how to change that?
          Looking forward to the feature in 2.0.
          • ke_sheng_jie
            • Aug 2011
            • 40
            Work Around
            Found the work around in the source code in src/libs/zbxcommon/str.c, the severities are at lines 2550-2563. So far, I haven't seen any issues caused by changing this and recompiling, but your mileage may vary.
            Does the 2.0 feature allow for the change to include the email notifications sent?
