SNMP Query values
  • RohrbaGe
    • Aug 2005
    • 167
    SNMP Query values
    I have running zabbix 1.1b6 on a Suse Linux 9.2 server.
    I´m trying since a while to read the fan states and temperature
    of some cisco switches without success.
    I have compiled with the --net-snmp and I already read
    a temperature of a UPS by SNMP. So in generell it works well.
    The OID for the fan state is: 1.3.6.1.4.1.9.9.13.1.4.1.3.1
    But I´m not able to read that with snmpget.
    The following command works on the cisco.
    snmpget -v1 -c public <ip> system.sysDescr.0
    With snmpwalk I got a long list like that.
    IF-MIB::ifConnectorPresent.1 = INTEGER: true(1)
    SNMPv2-SMI::mib-2.17.5.1.1.4.1.128.194.0.0.4.33 = INTEGER: 3
    I guess I have a generall understanding problem.
    Is it necessary to have the mib files for the cisco installed on the Zabbix Server?
    What I have to do?
    Or should the following command already work? ( what it does not)
    snmpget -v1 -c public <ip> 1.3.6.1.4.1.9.9.13.1.4.1.3.1
    Regards
    Gerald
  • bbrendon
    • Sep 2005
    • 873
    if
    doesn't work from the zabbix server. you have a bigger problem. most likely cisco configuration error. And no, you don't have to install mibs.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • krusty
      • Oct 2005
      • 222
      if you go to your switches and make show running. Which community string you read? I think you have a general problem with snmp? May your switch doesn't support the mib? Can you do the following?
      snmpwalk -v 1 -c <community string> <IP>
      If this works, then read the dump and look at your MIB. If you found your MIB then try this:
      snmpwalk -v 1 -c <community string> <IP> <your MIB>
      If you dosen't found your MIB then your switch will not support this MIB.
      • RohrbaGe
        • Aug 2005
        • 167
        SNMP Cisco
        I think now also that the reason why it does not work is based on the cisco.
        Reading now hours in Google, and testing parallel I have some emore details.
        On the Cisco 3524XL is IOS 12.0 running.
        In config mode I should add snmp-server enable traps envmon.
        This the cisco does not like.
        And this envmon is no option
        CFSWT015(config)#snmp-server enable traps ?
        c2900 Enable SNMP c2900 traps
        cluster Enable Cluster traps
        config Enable SNMP config traps
        entity Enable SNMP entity traps
        hsrp Enable SNMP HSRP traps
        snmp Enable SNMP traps
        vlan-membership Enable VLAN Membership traps
        vtp Enable SNMP VTP traps
        <cr>
        Has anybody an idea, what I have to do on the cisco?
        Do I have to install something on the cisco?
        Regards
        Gerald
        • zabby
          • May 2005
          Please try 1.3.6.1.4.1.9.9.13.1.4.1.3.1.0
          OID must end with .0
          You do not need to have the mibs in zabbix if you use OID.
          • RohrbaGe
            • Aug 2005
            • 167
            Snmp
            I have done taht already during my tests.
            I have now analysed the Cisco,
            this OID is not in.
            But it should be.
            Gerald
