hi
new to zabbix, but spent most of yest reading the wiki and setting it up, both server and agent are running... but i think i have an issue with firewall as zabbiz-server is not filling up
installed zabbix server on ubuntu server 11.04 in virtualbox, hosted on ubuntu 11.04 desktop, and have forwarded the ports on the VM as so:
8888 > 80 for frontend access
2000 > 22 for ssh
both work fine
10051 > 10051
10050 > 10050
these are listening on the respective machines:
the agent is running on my router a dd-wrt flashed wrt600n, with optware and custom template
agent conf is:
and nothing interesting in the debug log:
on the zabbix-server i have set up dd-wrt host as:
in group: linux servers
ip add: 192.168.1.1
port: 10050
and linked the dd-wrt template.
so do i need to forward the 10050/10051 on the router? or the ubuntu desktop? i thought adding the port forwards to the VM sorted that side out and as it is reporting back through my LAN i figured don't need any forwards on the router side.... but something somewhere is stopping it !!!
my second attempt at getting this going (gave up 6 odd months ago) and feel as if i'm so close
any help appreciated, thanx!
2000 > 22 for ssh
both work fine
10051 > 10051
10050 > 10050
zabbix@zabbixvm:~$ netstat -antp | grep zabbix (Not all processes could be identified, non-owned process info will not be shown, you would have to be root to see it all.) tcp 0 0 0.0.0.0:10051 0.0.0.0:* LISTEN 2125/zabbix_server root@DD-WRT:~# netstat -antp | grep zabbix tcp 0 0 0.0.0.0:10050 0.0.0.0:* LISTEN 18293/zabbix_agentd
agent conf is:
# This is config file for zabbix_agentd # To get more information about ZABBIX, go http://www.zabbix.com ############ GENERAL PARAMETERS ################# # List of comma delimited IP addresses (or hostnames) of ZABBIX servers. # No spaces allowed. First entry is used for sending active checks. # Note that hostnames must resolve hostname->IP address and # IP address->hostname. Server=192.168.1.120 # Server port for sending active checks # ServerPort=10051 # Unique hostname. Required for active checks. Hostname=DD-WRT # Listen port. Default is 10050 #ListenPort=10050 # IP address to bind agent # If missing, bind to all available IPs #ListenIP=127.0.0.1 # Number of pre-forked instances of zabbix_agentd. # Default value is 5 # This parameter must be between 1 and 16 StartAgents=5 # How often refresh list of active checks. 2 minutes by default. #RefreshActiveChecks=120 # Disable active checks. The agent will work in passive mode listening server. DisableActive=1 # Enable remote commands for ZABBIX agent. By default remote commands disabled. #EnableRemoteCommands=1 # Specifies debug level # 0 - debug is not created # 1 - critical information # 2 - error information # 3 - warnings # 4 - information (default) # 5 - for debugging (produces lots of information) DebugLevel=5 # Name of PID file PidFile=/tmp/zabbix_agentd.pid # Name of log file. # If not set, syslog will be used LogFile=/opt/var/log/zabbix_agentd.log # Spend no more than Timeout seconds on processing # Must be between 1 and 30 Timeout=3 ####### USER-DEFINED MONITORED PARAMETERS ####### # Format: UserParameter=<key>,<shell command> # Note that shell command must not return empty string or EOL only #UserParameter=system.test,who|wc -l ### Set of parameter for monitoring MySQL server (v3.23.42 and later) ### Change -u<username> and add -p<password> if required #UserParameter=mysql.ping,mysqladmin -uroot ping|grep alive|wc -l #UserParameter=mysql.uptime,mysqladmin -uroot status|cut -f2 -d":"|cut -f1 -d"T" #UserParameter=mysql.threads,mysqladmin -uroot status|cut -f3 -d":"|cut -f1 -d"Q" #UserParameter=mysql.questions,mysqladmin -uroot status|cut -f4 -d":"|cut -f1 -d"S" #UserParameter=mysql.slowqueries,mysqladmin -uroot status|cut -f5 -d":"|cut -f1 -d"O" #UserParameter=mysql.qps,mysqladmin -uroot status|cut -f9 -d":" #UserParameter=mysql.version,mysql -V UserParameter=mvcheck, /opt/usr/sbin/mvcheck UserParameter=listenport[*], netstat -ln | grep -c ':$1 ' UserParameter=net.netstat, netstat -lnt | sort UserParameter=net.netstat.cksum, netstat -lnt | sort | md5sum | tr -cd 0-9 | cut -b1-10 UserParameter=system.topcpu[*],/opt/usr/sbin/topcpu $1 $2 UserParameter=net.iptables.cksum,sudo iptables-save | grep -v '^[#:]' | md5sum | tr -cd 0-9 | cut -b1-10 UserParameter=net.ipv4.cksum,ifconfig | grep -B1 ' inet ' | md5sum | tr -cd 0-9 | cut -b1-10 UserParameter=net.ipv4,ifconfig | grep -B1 ' inet ' | grep -oE '(^[a-z0-9:]+|addr:[0-9]+\.[0-9]+\.[0-9]+\.[0-9]+)' UserParameter=net.connections, sudo grep -c . /proc/net/ip_conntrack UserParameter=nvram.cksum, sudo /usr/sbin/nvram show 2>/dev/null | grep -vE '^(wan_[ig][aep]|forward_|traff|dnsmasq_lease_|http_client_)' | sort | md5sum | tr -cd '0-9' | cut -b1-10 UserParameter=nvram.free, sudo /usr/sbin/nvram show 2>&1 1>/dev/null | grep -o ' ([0-9]*' | tr -cd '0-9' UserParameter=vfs.file.regcount[*],sudo /opt/usr/sbin/regcount "$1" "$2" "$3" "$4" "$5" UserParameter=vfs.file.regtop[*], sudo /opt/usr/sbin/regtop "$1" "$2" "$3" "$4" "$5" "$6"
root@DD-WRT:~# cat /opt/var/log/zabbix_agentd.log 17500:20110831:180805 One child process died. Exiting ... 17500:20110831:180807 ZABBIX Agent stopped. ZABBIX 1.6.2. 18293:20110831:180811 zabbix_agentd started. ZABBIX 1.6.2. 18293:20110831:180811 cfg: para: [Server] val [192.168.1.120] 18293:20110831:180811 cfg: para: [Hostname] val [dd-wrt] 18293:20110831:180811 cfg: para: [StartAgents] val [5] 18293:20110831:180811 cfg: para: [DisableActive] val [1] 18293:20110831:180811 cfg: para: [DebugLevel] val [5] 18293:20110831:180811 cfg: para: [PidFile] val [/tmp/zabbix_agentd.pid] 18293:20110831:180811 cfg: para: [LogFile] val [/opt/var/log/zabbix_agentd.log] 18293:20110831:180811 cfg: para: [Timeout] val [3] 18293:20110831:180811 cfg: para: [UserParameter] val [mvcheck, /opt/usr/sbin/mvcheck] 18293:20110831:180811 Accepted configuration parameter: 'UserParameter' = 'mvcheck, /opt/usr/sbin/mvcheck' 18293:20110831:180811 cfg: para: [UserParameter] val[listenport[*], netstat -ln | grep -c ':$1 '] 18293:20110831:180811 Accepted configuration parameter: 'UserParameter' = 'listenport[*], netstat -ln | grep -c ':$1 '' 18293:20110831:180811 cfg: para: [UserParameter] val [net.netstat, netstat -lnt | sort] 18293:20110831:180811 Accepted configuration parameter: 'UserParameter' = 'net.netstat, netstat -lnt | sort' 18293:20110831:180811 cfg: para: [UserParameter] val [net.netstat.cksum, netstat -lnt | sort | md5sum | tr -cd 0-9 | cut -b1-10] 18293:20110831:180811 Accepted configuration parameter: 'UserParameter' = 'net.netstat.cksum, netstat -lnt | sort | md5sum | tr -cd 0-9 | cut -b1-10' 18293:20110831:180811 cfg: para: [UserParameter] val [system.topcpu[*],/opt/usr/sbin/topcpu $1 $2] 18293:20110831:180811 Accepted configuration parameter: 'UserParameter' = 'system.topcpu[*],/opt/usr/sbin/topcpu $1 $2' 18293:20110831:180811 cfg: para: [UserParameter] val [net.iptables.cksum,sudo iptables-save | grep -v '^[#:]' | md5sum | tr -cd 0-9 | cut -b1-10] 18293:20110831:180811 Accepted configuration parameter: 'UserParameter' = 'net.iptables.cksum,sudo iptables-save | grep -v '^[#:]' | md5sum | tr -cd 0-9 | cut -b1-10' 18293:20110831:180811 cfg: para: [UserParameter] val [net.ipv4.cksum,ifconfig | grep -B1 ' inet ' | md5sum | tr -cd 0-9 | cut -b1-10] 18293:20110831:180811 Accepted configuration parameter: 'UserParameter' = 'net.ipv4.cksum,ifconfig | grep -B1 ' inet ' | md5sum | tr -cd 0-9 | cut -b1-10' 18293:20110831:180811 cfg: para: [UserParameter] val [net.ipv4,ifconfig | grep -B1 ' inet ' | grep -oE '(^[a-z0-9:]+|addr:[0-9]+\.[0-9]+\.[0-9]+\.[0-9]+)'] 18293:20110831:180811 Accepted configuration parameter: 'UserParameter' = 'net.ipv4,ifconfig | grep -B1 ' inet ' | grep -oE '(^[a-z0-9:]+|addr:[0-9]+\.[0-9]+\.[0-9]+\.[0-9]+)'' 18293:20110831:180811 cfg: para: [UserParameter] val [net.connections, sudo grep -c . /proc/net/ip_conntrack] 18293:20110831:180811 Accepted configuration parameter: 'UserParameter' = 'net.connections, sudo grep -c . /proc/net/ip_conntrack' 18293:20110831:180811 cfg: para: [UserParameter] val [nvram.cksum, sudo /usr/sbin/nvram show 2>/dev/null | grep -vE '^(wan_[ig][aep]|forward_|traff|dnsmasq_lease_|http_client_)' | sort | md5sum | tr -cd '0-9' | cut -b1-10] 18293:20110831:180811 Accepted configuration parameter: 'UserParameter' = 'nvram.cksum, sudo /usr/sbin/nvram show 2>/dev/null | grep -vE '^(wan_[ig][aep]|forward_|traff|dnsmasq_lease_|http_client_)' | sort | md5sum | tr -cd '0-9' | cut -b1-10' 18293:20110831:180811 cfg: para: [UserParameter] val [nvram.free, sudo /usr/sbin/nvram show 2>&1 1>/dev/null | grep -o ' ([0-9]*' | tr -cd '0-9'] 18293:20110831:180811 Accepted configuration parameter: 'UserParameter' = 'nvram.free, sudo /usr/sbin/nvram show 2>&1 1>/dev/null | grep -o ' ([0-9]*' | tr -cd '0-9'' 18293:20110831:180811 cfg: para: [UserParameter] val [vfs.file.regcount[*],sudo /opt/usr/sbin/regcount "$1" "$2" "$3" "$4" "$5"] 18293:20110831:180811 Accepted configuration parameter: 'UserParameter' = 'vfs.file.regcount[*],sudo /opt/usr/sbin/regcount "$1" "$2" "$3" "$4" "$5"' 18293:20110831:180811 cfg: para: [UserParameter] val [vfs.file.regtop[*], sudo /opt/usr/sbin/regtop "$1" "$2" "$3" "$4" "$5" "$6"] 18293:20110831:180811 Accepted configuration parameter: 'UserParameter' = 'vfs.file.regtop[*], sudo /opt/usr/sbin/regtop "$1" "$2" "$3" "$4" "$5" "$6"' 18294:20110831:180811 zabbix_agentd collector started 18295:20110831:180811 zabbix_agentd listener started 18296:20110831:180811 zabbix_agentd listener started 18297:20110831:180811 zabbix_agentd listener started 18298:20110831:180811 zabbix_agentd listener started
ip add: 192.168.1.1
port: 10050
